Hello Support. I have 4 rooms for the robot to clean but the doorsteps are too high so I'd have to move it manually. Do I also have to move the charging base or is the robot enough? And will it save the maps of those rooms?
Moving the charging base might be necessary if it can not navigate over the doorsteps. As for saving maps it depends on the robots capabilities so checking its documentation or contacting support would be helpful.
To create a map, the robot needs start from the dock and cleaning everywhere and return to the dock automatically. Usually we do not suggest customer to move the robot manually while cleaning, it may mess up the map. But you can give it a shot.
Besides, the current S5 Max supports multi-floor maps feature, if it does not create the map properly, you can divide them into several maps to satisfy your needs.
The doorstep symbolizes more than just an entryway; it's a threshold of opportunity and connection. Whether it's a welcoming sight after a long day or a gathering place for conversations with neighbors, the doorstep holds significance in our daily lives. It's where we leave behind the outside world and step into the warmth of home. For reliable healthcare needs, https://canadianinsulin.com/offers accessible solutions at your doorstep.
You do not have to move the dock along with the robot, only the robot is needed.
Besides, please ensure that the multi-floor maps feature is enabled as pic attached.
Thank you for the reply. Just got the update and it works great.
Great to know that. Congrats.
Lawn Installation Services in Surfside Beach
Hi Support,
I am planning on buying a Xiaomi S5 Max for my house. I have a one-level house with several, probably too high door steps.
Is it possible to physically move the robot and have the robot continue to draw on the same map?
Or will the move be seen as a new level and a new/another map will be drawn?
Hi, thanks for your requesting.
