dustruffle seems to be an insurmountable obstacle
It isn't even all the way to the floor but "Pat" won't go under the guest room bed unless I pin up the dust ruffle.
    Could you provide more details about the current issue so that we can have a better understanding and give you a proper solution once the problem is confirmed.
    Could you tell us your device's info?
    Make sure robot is connected to app and go to robot's setting, click "copy all" and then paste all the text (not picture) in your email. See attached picture"info".
marty
