Dividing Room on Map
I am in edit map mode, i select Edit room, then Divide. I am trying to divide this large GRAY region, but tapping in that area doesn't do anything. If i tap in other areas, i get a divider.
Any ideas here?? Buggy software?
  • sorry, Roborock s6maxV on 1.40.86
    RR_SupportStaff Member06/11/2020      07:35
    @Daggit:
    Hello, the gray area means that it does not be recognized. Set zone cleaning with the gray area included and then verify whether it can be detected.
    If it does not work, we suggest you to reset the map and re-map the house by starting the robot from the dock.
    Also, you can move the dock's position to a more central place of the house to give it a shot.
Daggit
