I do not see any option to schedule a single room to be cleaned. (Or a set of rooms). Basically, i want a subset of my saved map to be cleaned at 3am but there is no way to specify what to clean via the scheduler. I must be blind, as this is a pretty obvious function to be included with my 750$ robot.
Please see the video I created at https://youtu.be/va6uf9Cmaws for help with this.
I want to suggest DeskFlex Room Scheduling Software. it will help you to manage your room schedule. you can customize your scheduling to using DeskFlex Software.
https://www.deskflex.com/
What is the model number of your robot?
Did you enable the multi-floor maps feature? If so, sorry that it doesn't support the schedule room cleaning feature with Multi-floor map saved mode enabled.
Since the vacuum may not locate at the certain floor when cleaning a room with the schedule.
But thanks for your feedback. Would you please let us know the detailed situation for schedule room cleaning feature and Multi-floor map simultaneously?
Based on this situation, we will forward your advice to our R&D department and hope they will add this feature in the future. But at this moment, we could not promise you anything.
Your understanding and cooperation are highly appreciated!
Y'all mention enabling this feature all the time, but I can't find where you tell us how to turn it off. It seems to have been turned on by default when I got my vacuum.
Do you mean the multiple-floor feature? If that's the case, here's where you can turn it off.
