My robot is offline for a while now. In the last couple weeks I tried different server locations, router reset, 8.8.8.8 as DNS und multiple resets. I can connect to the device with Mi Home after a reset. But the WiFi LED keeps flashing fast after the initial binding and the app is waiting for response. What else can I do?
Same thing. Would be happy for suggestions
Hello, sorry for the inconvenience caused here.
It is permanently offline. It will connect to the app, but then never goes online.
The wifi indicator is flashing fast
No, a reboot does not change anything
All other wireless devices work. I placed the robot close to the router. I created a new 2.4 GHz wifi. No success. But I can see the robot as a connected device at the router and it is transmitting and receiving limited data. All other devices on the same router access the Internet without any problems.
The router is a gl.inet 750m with a LTE modem. No change for the last year. The roborock problem started two month ago.
Hi, thanks for your reply.
So the robot failed to connect to the home wifi.
You can try methods below:
1. Make sure the password of your wifi you've input is correct.
2. Don't use an android tablet, iPad, iPhone 5 or iPhone 5C to connect the robot as there might be a compatible issue.
3. Enable location permission like attached picture.
4. Make sure the current region you've selected on Mi Home setting is correct. Please don't select the China mainland. See attached picture "region"
5. Make sure the model you've selected is correct when setting up via iPhone. Please select the Xiaowa E series on the list if the model is E2(E20 or E25) or E3(E35).
6. Pay more attention to the select wifi step. See attached picture "select your home wifi".
7. The failure message on the app might be fake. If the wifi indicator of the robot becomes solid from blinking, it means it's already connected to wifi successfully. Kill the Mi Home app and open it again to see if the robot is on the device list.
8. If there are special characters like !@#$ contains in your wifi name or password, it's suggested to log in to the router and remove them in the wifi settings.
9. The robot doesn't support WEP encryption mode. If your wifi is WEP, change it to WPA or WPA2. You could also try to change the wifi channel.
10. If you understand the router's setting very well, try to change DNS to 8.8.8.8 in the router's settings page.
Also, you can try to connect to the mobile hotspot. You must get 2 smart phones( A and B) .
I have exactly the same problem. From these posts, I conclude that this is most likely a software issue, and not a real failure. All the support people do is give pre established suggestions, designed for non technical people.
The factory reset is not a full reset.
I am very disappointed at this stage with what is going on.
Hello, we are sorry for the inconvenience caused here.
You can provide more details:
1.The model number
2.A detailed description of the current wifi disconnection issue.
3.The troubleshooting methods you have done.
Hello, I tried all as suggested. wifi indicator is flashing fast, but the device does not connect to the app - "bring device closer to router". It's roborock s5. To note - same device used to connect easily before, no changes in the wifi settings or anything else.
Try to connect it to the mobile hotspot and verify whether it works. Also, you can take some time to monitor its stability.
Same problem here how to resolve
We feel sorry for the inconvenience caused.
You can try reboot the device to see if the device can be back online automatically (long press the power button to switch off the device and then long press the same button to switch it back on) when you find the device offline.
If it can not be online automatically, we suggest you reset the wifi to have a try to see if the wifi can be connected again.
Please check that the machine works within the coverage of your router.
