Roborock S6 Internal Error
Keep getting an internal error with reference to the left wheel. I reset to factory settings and re-updated the firmware back to the latest (01.19.98) but still getting the error. I cleaned the wheel to make sure it didn't have any debris. It will run for 15-20 minutes then has the internal error. In the app, it lists the error as follows, "Internal Error - Malfunction due to an internal error. Reset the robot. Error: 106 Left wheel open circuit."
    Sorry for the inconvenience caused.
    Please email us the info below via support@roborock.com.
    1. Please take out the dust bin and check the serial number on the label.
    2. Please send us the purchase info, with seller, order number, purchase date, product and price included.
    Mike
    Mike12/11/2021      14:37
    My S6MaxV has developed this issue too. I have read else where it could be as simple as taking the whee out and cleaning. Or is it the wheel module that needs to be replaced?
    Thanks
    —Mike
    RR_SupportStaff Member12/16/2021      16:39
    @Mike:
    You can try the methods below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    Without professional testing, it's hard to tell where the issue lies exactly. Also taking out the wheels requires professional skills. If the issue can not go away, please contact support@roborok.com to get further assistance.
  • This is me now. An S6 MAX… Error:105 Left wheel short circuit
    RR_SupportStaff Member01/12/2023      16:47
    @Andy:
    Hello, thanks for reaching out. May I know if you've tried the methods below?
    Notice:
the4mula
