S5 - Roborock app
S5 - Roborock app
Hello. I bought S5, but it the only one not supported in your Roborock app. How can I use it best?
1- How can I save 2 versions of the same map?
  • Map Version A: blocking the furniture
  • Map Version B: without blocking them
2- in Xiami Home app, it is the option to have A second house, but I cant manage to use it with the vacuum. How can i make it work?
thank you.
    The S5 supports Mi Home app only.
    Could you send us the pictures of the two versions of the map.
    The S5 does not support multi-floor maps feature; you can use it to clean different houses, but it will reset the previous map and create a new map at each time if you move the robot to another house manually.
Gabriella
