Reverting from multi floor to single floor
So I have mapped my first floor on the "multi-floor" setting, and want to revert the settings back to single floor as I need to schedule the clean ups. My question is, will it delete my map if I revert the settings to single floor? I only have one map at the moment. Thanks!
    Now only one map is stored, you can disable multi-floor maps feature directly and use the schedule room cleaning feature, it won't delete the current map.
    Like2
    Jen Z
    Jen Z07/14/2020      05:37
    Thank you! This helped 😁
    RR_SupportStaff Member07/16/2020      07:40
    @Jen Z:
    You are welcome. it is glad to help you.
Jen Z
