So, I got a Roborock S6 MaxV, and I'm very happy with it. It works as intended, and does a good job. So on the hardware side, I don't have any real suggestions for improvement.
But I have a few on the software/app side:
- Whenever it sees an object, it should take a photo. Not only the ones that the AI feature recognizes. Right now it just shows a cone-icon and says "Avoided", but no picture of what it actually is that it avoided. It's great to show what the AI recognizes (or thinks that it recognizes) but it would be even better if I could actually see what it avoided but didn't recognize, so I can try and remove the obstacle before the next run.
- Request a live/instant image from the camera through the app. The best would be a live stream, but if not, then just a button to "Take a picture", so in case it gets stuck while i'm not home, at least I can see if it's a shoe, a carpet, or my cat's tail! ;) ... or simply if I'm just curious what's in front of it right now.
- When editing the map to add no-go zones and all these things, it would be nice if it was possible to change the individual corners of a square, so it's not just a square. Also, it would be nice if you could add circles or other shapes instead of just a square (e.g. I have a chair in the living room with a round foot, that it keeps getting stuck on. Would be nice if I could circle it out, instead of a square, that makes it go way too far away from the chair.
- An "Initialize map" feature. Would be nice if you could just let it drive around on it's own, to map the room, the first time you set it up, or put it in a new house/floor. It's not necessary to do a full clean of the house, with the very "narrow" vacuum-pattern, when the LiDAR could probably do it pretty quickly just by driving around, following the walls first, followed up by a bit more "rough" square pattern in the room, to catch other objects. This could probably do the mapping in less than half the time of a vaccuum. After that, you can add all the No-go zones, room divisions and stuff, and then do a clean to confirm everything is working properly.
- It would be nice if you could "erase walls" in the map editor. For some reason, my couch (which is more than 15cm above the ground, so plenty of space for it to get under it) is recognized as a wall, which makes the vacuum-pattern a bit more confusing. If I could go to the map-editor, and then with a "Wall eraser"-feature, simply erase walls (that are not really walls) manually by sliding my finger over it, then it would be perfect. Of course, the robot should remember in the future, that it shouldn't recognize walls in this area again.
- An option to show/hide all the map configurations. It's nice to see all the no-go zones and no-mop zones and walls, when you're in map editor mode. But when you're just looking at the map of the house, when it's running, then it can be a huge mess to look at. So a toggle-feature to show/hide all the zones would be nice, so it's just the room-colors (that is added when dividing rooms), all areas that are no-go zones are grayed out (made more transparent), and maybe also the settings (vacuum-strength and water level). The best would be to have a menu where you check off all the stuff you want to see on the map-overview when you look at the map, but a fixed toggle feature would be fine.
- Correct AI recognition? I'm actually a bit surprised that it's not there. A lot of the time, the AI is very wrong. Most of the stuff it sees on the floor is categorized as shoes, for some reason. And yesterday it recognized a window curtain as poop. Wouldn't it be nice if I could click a button and correct whatever the AI thought it was? And when it doesn't recognize things (like in my 1st suggestion) I would be able to set a category that matches? That would not only help you improve your AI, with help from you, but in the future, maybe the robot would simply know that the thing in my living room, that looks like a shoe, is actually a cat toy. Or that the curtain is actually not a poop, so it's okay to move to that corner of the room.
Tell me what you guys think? Any of these features you would like to see, and if yes, do you have any extra suggestions to any of them, to make them even better? :)
Hope that the Roborock Developers would consider some of them, or maybe say if some of them are already on your roadmap for upcoming features?
Thanks!
Thanks so much for such detailed feedback. We appreciate them very much. Keep following us. We would announce any update on S6 MaxV. Have confidence in our engineers who are trying hard to make it better. Roborock won't miss any chance to improve our products.😊
The discussion highlights exciting advancements in AI-powered home robots like the S6 MaxV. As conversational technology like ChatGPT also rapidly evolves, integrating more natural voice control and intelligent assistance could further enhance these devices. Experience Ai technology completely free with ChatGPT: https://gptdeutsch.com/
ChatGPT Polsku zyskuje coraz większą popularność. To nie tylko efekt wysokiej jakości treści czy przyjaznego interfejsu, ale także zaangażowania eksperta ds. badań nad sztuczną inteligencją, Bengta Ariena, oraz niezwykle szybkiego systemu reakcji chatbota. Dzięki temu serwisowi otwierają się przed nami nowe horyzonty wirtualnej komunikacji i odkrywania wiedzy.
Aby uzyskać więcej informacji, zobacz : https://chatgptpolsku.org/
Informacja :
Adres : Polna 8B,Bydgoszcz, Poland
Naród : Poland
Miasto : Bydgoszcz
Kod pocztowy : 85-163
Telefon : +48 691-404-165
E-mail : info@chatgptpolsku.org/chatgptpolsku@gmail.com
Moja strona internetowa : https://chatgptpolsku.org/
#ChatGPTPolksu , #chatgptpolsku.org , #chatgptdarmo
It's fantastic to see your positive experience with the Roborock S6 MaxV! Your thoughtful suggestions for improvements on the software/app side are insightful. 💡 The idea of capturing photos of objects it encounters and providing live/instant images for remote monitoring are especially intriguing. ChatGPT (https://gptnederlands.nl/) also plays a role in enhancing AI capabilities, so it's possible that refining AI recognition could make the robot even smarter. Your input here is invaluable in shaping the future of robotics and smart home technology. Let's hope Roborock considers these enhancements in their roadmap!
These are some quick and very easy suggestions. I'll try to add them in
ChatGPT (チャットGPT)日本語 - 登録なし | OpenAI - チャット GPT Japan
https://chatgptjapan.org/チャットgpt for sure.
Thanks for a detailed article on this topic. will surely use this feedback on my website. If you want to know further about this topic visit https://chatgptfrench.org/.
Thank you for providing such thorough feedback; we value it greatly. Please continue to stay connected with us. Any updates regarding S6 MaxV will be communicated. For additional information on this subject, visit http://chatgptsvenska.org/ .
Hello there,
It's great to hear that you're enjoying your Roborock S6 MaxV, and you've raised some excellent suggestions for improving its software and app features. Let's break down your ideas:
Your ideas align with enhancing user control and convenience in using the Roborock S6 MaxV. You can check for more at ChatGPT Nederlands (Dutch) - Geen Registratie | OpenAI - ChatGPT Dutch .These suggestions could significantly improve the user experience, and we hope the Roborock development team considers them for future updates.
If anyone else has additional thoughts or ideas to add, please feel free to share them!
あなたの洞察は実に貴重であり、このような有益な情報を提供するための努力に感謝している。
チャットGPT 日本語 (ChatGPT) 登録不要で無料 |AIチャットボット
https://xn--gpt-1l4bk4a7o.cochat gptを使えば、より多くのアイデアを得ることができます。
Hi there, I enjoy reading all of your article. I like to write a little comment to support you. The article is very meaningful. Its contribution has been immense in improving user interactions and efficiency. To access ChatGPT in Israel, visit this link:
צ'אט GPT (Israel) - אין רישום | OpenAI
https://chatgptisrael.net/ChatGPT Israel .
great work and thanks for sharing this.
ChatGPT Español (Spanish) - Sin Registro | OpenAI
https://chatgptspanish.io/ChatGPT Français (Gratuit) - Pas d'inscription | OpenAI
https://chatgptfrancais.co/ChatGPT(チャットGPT)日本語無料版 - 登録不要 | OpenAI
https://chatgptjapanese.com/As we progress further into the digital age, AI chatbots have become an integral part of our day to day communication. They have proved to be incredibly helpful in assisting online users to find the information they need without the hassle of scrolling through numerous web pages or contacting customer service. One of the most advanced AI chatbots on the market is OpenAI’s ChatGPT – an incredibly smart and versatile tool that can answer questions and engage in conversations in a way that mimics human communication. In this blog post, we’re going to take a deeper dive into ChatGPT online, discuss its history and functionality, and discover how you can use it for your benefit.
Awesome Stuffs
You can try the awesome https://chatgdp.org for free, and get accurate results
Hello. Now on the Internet there are a large number of services with which you can check your work for plagiarism, I use check for plagiarism in google docs https://plagiarismcheck.org/google-docs-add-on/ to use tables to check your data for plagiarism
