I updated my S6 to the 3.5.8 firmware when it became available for me last week. Multi floor support and all, which is nice... but I only have one floor to use it on.
Since then, the Roborock experienced a never-before-seen glitch where it thought my kitchen was longer than it really was, and now the map is messed up. The map has shifted. I saw another thread from someone else who had the same exact problem with the S6 on the new firmware, but the thread seems to have been deleted.
The new firmware is also less accurate at keeping consistence between rooms. Some rooms end up diagonal. And the removal of the backup maps feature means the map just gets worse every day — these random glitches and mistakes degrade the map with every run. The backup maps kept it at a baseline of your choice.
Did you enable the multi-floor maps feature? If you use it on one floor only, it is suggested to disable this feature.
Back to your case, please send us a picture of the home map interface. And go to cleaning history and send us a full cleaning map which shows the layout of the house correctly.
Use wet cloth to clean the cliff sensors and wall sensor.
Besides, you can move the dock's position and re-map the house to have a try.
Hi, I’m not comfortable posting my floor map here, and I had to delete the map and start over. I don’t have multi-floor mode on, and never had it on.
The main problems with the new firmware: there are no backup maps in the new firmware. Please bring those back, so we can revert to them if the map gets messed up. With the new firmware, the map will get worse and worse, little by little, every time you run the vacuum. Also, there is a mapping glitch with the new firmware, as proven by this post and the previous guy’s post with the exact same problem.
Sorry for that. Taken your feeling into consideration, you can email us via support@roborock.com if you have more question.
For the backup maps feature, we will forward it to our tech team and hope that they can manage it in the future. You can reset to restore the old firmware as a workaround. And if there is a newer firmware, you can install it and give it a shot.
