WIFI DETECTION
WIFI DETECTION
ANDROID PHONE CANNOT DETECT THE S5 MAX - i have tried everything in the instructions, troubleshooting, including online!
RECEIVED IT A LITTLE WHILE AGO, AND SUPPORT CLOSES AT 9AM PT (which doesn't help us too much!)
    What is the current wifi led indicator? Is it off or flashing?
    Turn off the wifi function on your Android phone and re-enable it to verify whether you can detect the robot's wifi.
    You can reset the wifi on the S5 Max to have a try.
    If it is still the same, you can hard reset it to have a try.
ROCKIE
