Roborock S5 Max Water Tank
Hi guy,
I have problem with my Robot. The water only comes out a little even i max the water in settings.
What must i check?
Regards,
Verdarb
    If the water comes out only a little or none at all, please try the methods below.
    1. Wet the mopping cloth before mopping, install it, and start the robot for 10 minutes with the wet cloth to see if the floor is mopped.
    2. Change another mopping cloth.
    3. Make sure there is no detergent in the water because it might block the air-in hole.
    4. Pump up air from the air-in hole (such as blow it) and see if there're any bubbles in the water. See attached picture.
    5. Pump water from the water-out hole (such as suck it) and see if there's any water coming out. See attached picture.
    6. Disable the carpet mode and try again. See attached picture.
Verdarb
