I have a Roborock S5 MAX. I am in Argentina. I tell them that
I am amazed with it, that I was able to connect, add it to the Roborock app,
but when using it it takes a long time to load the map, sometimes it takes 30
min to connect with Wi-Fi. It is true that my Wi-Fi 2.4 is quite bad, because
the internet service in my area is lousy, but I want to rest assured that this
is the problem and not the robot. Today, for example, I had it cleaning without
being able to show me in real time the map of my house (after 15 minutes it did)
because it wasn’t connected, that error arises in the connection that I leave
in the photo, and therefore I cannot enter to decide which plant I want to
clean. Today I made it clean the one that was recorded the last time. I lifted
the lid of the robot and the blue wifi light is continuous, I understand that
it is connected, but in the app it gives me an error in the connection, and it
takes a long time for the app to show me all the functions because it is not
connected. Today when I was trying to load the map, while the device was
cleaning, on two occasions it said it was offline. Then I try again and it
opens, but it doesn't load the map for waaaaay too long. I already appreciate
the help of technical support or a supportive member. Best regards
For the map loading issue:
3. What is the size of your house? not size already cleaned, but your house's whole size.
4. If you are using Mi Home, tell us which region your Mi Home selects and switch region to re-add robot to Mi Home to have a try. See attached picture.
5. Clear cache of app. See attached picture.
6. Reinstall app to have a try.
7. Pls use your phone data instead of wifi to see whether map will show up.
8.To rule out the wireless stability issue, you can connect the S5 Max to the mobile hotspot to have a test.
Thank you so very much for your help in advanced. Do I share the serial number of my robot here in the post? If I delete the cache and re-install the app does it deletes the maps that are already saved? Do I have to do the same thing I did the first time I used the robot all over again?
My house has two floors and each floor it's 39 square meters.
And the thing it does of not loading the maps it's when it's still in the dock and whem it's cleaning also. The app shuts down when my phone locks itself and sometimes it takes way too long to load the map. Lately I see that the map loads faster but it takes too long to connect to the wifi, follow that persistent error in the app. I will reinstall!
Hi Euge,
You can email us these information to protect privacy. support@roborock.com
Also, you can try to connect the S5 Max to the mobile hotspot to test the performance.
Thank you very much for your help but now its working propperly, we changed our router and the map is now loading correctly and enhancing to the wifi correctly.
The only awkward thing I'm noticing now its that on the top floor it put in the map that the charge dock its up there when its not true. I've never put it upstairs. And it's happened that the bot wont go back to where it started cleaning and tries to go back to de dock. Do I have to map the floor again??
