frame
Mop // Cleaning liquid // S5M
Hello guys,
Device manual advises not to use any cleaning liquids. Is there any mild cleaning liquids we could use when mopping?
We are in the cove-19 ear and water seems not to be enough :(
thank you,
  • Hello Tom,
    Usually, we don't suggest our customers add anything into the water because the bubble made by chemical substance in cleaner may block the filter and cause no water out. Customers could give it a shot. If all is fine, we think it is OK to add. But if anything wrong on mopping, please clean the tank with water and don't use the cleaner any more.
    Mart0
    Mart008/02/2020      17:30
    Can You, please, tell me, where is the water filter placed in S5 Max model? I know where are the filters in S5 model, but I didn't see it in Max model.
    RR_SupportStaff Member08/03/2020      10:55
    @Mart0:
    Hi, there is no water filter in S5 Max, with the detergent added, it may block the water out hole.
Tom
