Add route configuration (room 1, room 4, room 5) - integrate into timer, manual mode, Alexa (S5 MAX)
I saw that you have added room selective cleaning into the "timer menu" --> which is already a good improvement.
But what would be better is a "route configuration":
E.g.:
  • Route 1: Sleeping room1, Bathroom, Toilet (with existing options for various settings of cacuum + wet option OR fixed settings - same as already existing)
  • Route 2: Pre room, sleeping room2
  • Route 3: Living room, kitchen
Modes:
  • Special new mode for manually start one of the pre configured routes
  • Add route mode to timer (start route 2 at 11:30 every day)
  • Add route mode for manually start one route also for Amazon Alexa
Best regards
  • Thanks for all your detailed feedback. We would think it over.
    da_muhhh
    da_muhhh08/06/2020      18:20
    @RR_Suggestions:
    I think this route mode would also solve a lot of problems with 2 floor mode.... Each route should only be for one floor - route should only be "startable" of robot is at current floor.
da_muhhh
