Roborock S5 stopped cleaning rooms
I bought the S5 a month ago and it worked great.
Now it stopped cleaning the whole house, and just halts in room exits, or in invisible walls.
https://ibb.co/D9q3fKg
https://ibb.co/1sWMp8Q
Help?!
    From the pictures provided, it seems that the map saving mode has not been enabled yet. See pic below:
    After you enabled it, please re-map the house. When the robot is creating the first map:
    1. Map saved mode is enabled
    2. Robot starts from dock;
    Besides, use wet cloth to clean the wall sensor and cliff sensors.
whynb
