Roborock S4: Loading Map
My new Roborock is struggling with the app while cleaning. The app stops updating while the vacuum is cleaning and the dock/pause buttons don't work (from the app). I can edit the map, but the save fails. "Try again later." If I back out and come back in, it just says Loading Map and never pulls it in. Sometimes when it gets back to the dock, it will then update, but sometimes not and I have to remove it, reset all the wifi, re-pair the vacuum, and start the map all over again. Any thoughts on how I can make the network stick? I'm not having trouble with any other wifi component on the network, and I have strong signal throughout the house.
    Sorry for the inconvenience caused here.
    Please send us some pictures of the app when it does not respond. In the meantime, what about the wifi led? Is it solid or flashing blue?
    Please send us the device info.
    Try to clear the cache on the app, switch to cellular data.
    Besides, you can try to connect it to the mobile hotspot and verify whether it works well.
thetrev68
