S6 on new firmware making strange turns and cleaning only half the room
I started a room cleaning and the Roborock S6 randomly made these circular turns. It missed the top part of the room and made strange turns. This is after the 3.5.8 firmware update, which has brought all sorts of problems.
    Do other rooms have the same issue? Try to set full cleaning or zone cleaning and verify whether it works well.
    Use wet cloth to clean the wall sensor and cliff sensors.
    You mentioned that the latest firmware brought all these problems, did the S6 work properly before you updated it?
glinko3
