Using "Gentle" Mode All the Time
Is it ok to use "Gentle" mode all the time? Does it have sufficient suction strength to keep the floor clean? I have hard floor and no carpet...
I realised "gentle" is my favourite mode because it's the quietest ("Quiet" mode is still pretty loud IMO).
    FYI, Gentle mode(mop mode) will cut down the vacuum strength to lowest and robot will still vacuum when mop mode is enabled. Therefore, if you use it all the time, the vacuum performance will be affected.
    Besides, it will take effect once only, after robot finishes cleaning and backs to charge, the gentle mode will change to the previous cleanup mode.​
maxlaw01
Roborock S5 Max
