Differing cleaning patterns
I have attached a map showing an unusual pattern of cleaning in 2 rooms - the orange room on the right and the blu room at the bottom. The number of passes in the main area of the blue room is more than double the number of passes made in the main area of the orange room and they are approximately the same width. The vacuum seems to have mademuch smaller adjustments when turning in the blue room. This is apparent when watching the vacuum - it seems to go over each path twice. I have moved the dock since the original map was made but can’t see this being the cause as everything else is being cleaned normally.
Seems to be inefficient so I’d like to fix it
  • Here’s the map referred to in my previous post:
    RR_SupportStaff Member08/24/2020      08:31
    @Vander:
    Are those two rooms carpeted? Please send us some pictures of the actual rooms.
    Use wet cloth to clean the wall sensor and cliff sensors.
    Vander
    Vander08/27/2020      21:11
    Hello
    The room has low pile carpet.
    i have cleaned the sensors although they were clean.
    I repeated the clean and it seems to have cleaned normally - I will run it a few times over the next few days to see if the problem recurs.
    RR_SupportStaff Member08/28/2020      06:15
    @Vander:
    Hi Vander,
    Definitely sure, you can take more time to monitor its performance.
Vander
