The S5 Max can satisfy your needs. First, you can set no go zone or no mop zone and the robot will vacuum the rest areas but the no go zone, then you can remove the no go zone and make the robot vacuum and mop the specific area which you marked as no go zone/no mop zone earlier.
It is normal, robot won't go to the no-mop zone on map when mopping module is installed. Neither vacuuming nor mopping.
If you want to vacuum no-mop zone, you can uninstall the mopping pad, then the no mop zone will become invalid when mopping module is removed.
I think you should fix an algorithm. It should start to vacuum the dry and no mop areas first and then areas with the mop option
