RoboRock S5 Keeps saying "Charging"
The vac has worked normally until just recently.
It reports as 'off line' in the ap.
When I put it on the charging base is just plays the tune and says 'Charging' every 20 seconds or so.
I've monitored the charging voltage and it drops from ~20V to ~7V in the same timing...
What to do...?
  • Just taken out the battery and checked it - 6.6V
    If you have wiped charging contacts, could you send us pictures of charging contacts on dock and underneath of the robot as the attached picture "charging contact"?
    Also you can change another wall outlet to have a try.
CyprusGrump
