SELECT MAP FROM CLEANING HISTORY
It would be SO MUCH EASIER if you could just select and load a map from your cleaning history. Or give users the option to name maps, and assign them to a “Location”. Then when I move the unit “Upstairs”, I could then assign the (saved) map named “Upstairs” as the active map. As it is, when you go to your saved maps and select “Use Map” it doesn’t just switch out the active map for the selected saved map, it DELETES the active map all together. Trying to switch between maps for different floors is a joke.
  • Thanks for your suggestion about how to improve mopping feature. We will work hard.
    Master AUTO
    Master AUTO11/16/2020      13:55
    @RR_Suggestions:
    Roborock refuses to fix this issue with their robots. How hard is it to save a map to a directory and then load a map from a directory? I am soo disappointed. I will not buy another Roborock. They have been "working" on these map issues for over a year now.
  • I have no problem picking one of 4 maps on my Roborock S6. Don’t even need to move the charger to different floors or levels. It just says can’t find the charger and goes back to where it started. Love it!
ElsieK
