Power off the roborock, then power it back on and make it return to dock. You may need to pick it up and place it close to the dock for it to work, then you can verify whether Its location gets updated on the map.
We don't suggest you move the roborock in the middle of cleaning because that may confuse the robot and increase the chance of false positioning.
If the issue happens, you can try and bring the device back to the dock. Then let the robot start from the dock, and then wait util it's about 1 meter away from the dock, then press the dock button to let the robot go back to dock. Once it's docked, please check if the dock's position is updated or not.
Hi there! And what if it's not working and the position of the docking station isn't changing?
The given advice from 11/06/2020 didn't work for me.
This simple YouTube tutorial helped me out:
https://www.youtube.com/watch?v=Ecd__vxKjhs&t=161s
If no, you may need to remap the house :(
