First Mapping
First Mapping
The maps function didn't work on my S6Max V cvery well at all . So I am reseting the maps
Questions. On the first mapping, I have areas that the unit get caught up on and stops. Is there a way to set up no go zones "on the fords mapping, or do I need to block the area
For example I have high pile area rugs the unit does not like, how to I avoid these areas on the first mapping so I can get a clean map of my house ?
    Go to cleaning history and send us a problematic cleanup map.
    Does it get stuck in certain area? If yes, please send us some pictures of it.
    Also, please send us some pictures of the rug you use.
    With map created, you can click "edit map"-"no go zone" to set no go zone or invisible wall to avoid some specific area.
    Besides, if the water tank is installed, uninstall it and start it cleaning.
NEO
