Using the RoboRock app Android maps
I am using the Android version of the RoboRock app. I see posts and videos of people saying it creates the original map and then 2 back up maps. I am not seeing any back up maps. My real question is can I have at least 2 maps for my floor plan, 1 for total vacuum cleaning (completed and saved already), and second one I can set no go zones for my hard surfaces to do mopping. I have area rugs I want to work around and take advantage of the mopping capability. The robot I own is a S6 Pure. Any suggestions?
    Thanks for your info.
    S6 Pure does not support backup maps anymore, instead, it supports multi-floor maps feature, which means you can create up to 4 maps for your multi-story house.
    Back to your case, we do not suggest you create two maps for the same floor, because the robot may get confused.
Compros
