Rotate map or cleaning zones
My flat has a wall that is rotated by 30° compared to all other walls. Unfortunately this wall was used to orient the whole map, thus my whole flat is rotated by 30°.
It would be great to be able to rotate the whole map.
A second problem is that cleaning zones cannot be rotated, so in most cases I cannot clean the zone I actually want to be cleaned.
It would be great to be able to rotate cleaning zones.
Seddy
