Been playing with my S6 MaxV and got the following questions
- I had named rooms with more than one word (e.g. "Child's Bedroom") but I couldn't use these names in a Google Assistant command. When I changed it to one word, it worked fine. Is this correct?
- Now I have room names in my list that I won't use because they have two words. Is there a way to delete those names?
- Is it possible to use Google Assistant to clean multiple rooms? For example "Hey Google - start vacuuming room 1, room 2, room 3 and room 4?"
Thanks
There is no limit regarding the length of the room name, it may recognize the voice command incorrectly. You can try to change room name, like bedroom of Children.
Also, you can go to "edit map"- "edit room" page to change the room name.
It does not support cleaning multiple rooms via voice command at the same time now.
