S5 Max map issues
S5 Max map issues
I started using s5 max three weeks ago and I face the map issue twice. The position/angle of the map just shifted and I have to draw the whole thing again
it is such a waste of time to redraw the map as I have to move away obstacles while it’s drawing the map
this is how the messed up map looks like. The map was extended and the robot used 247min to try to figure out the map until the battery drained. The dock’s position has also changed in the map
usually the robot takes around an hour to clean up the whole place. Even this cleaning session had an issue where there’s one part missed out by the robot
So how should I fix this issue? I do not wish to keep redrawing the map again and again
    Is there any mirror or glass on your house?
    Do those gray area exist actually?We suggest you move the dock's position to a more central area.
    The space for the dock should be no less than 0.5 m wide on the left and right side, and 1.5 m wide in front of i
SSW
