I received my S5 Max order just now, and I am not able to set it up, as it doesn't detect in the Roborock app. I have followed the following steps (repeatedly):
- Download the app from google play store scanning the barcode from the pamphlet inside the box.
- The app detects an S5 Max, tries to connect to the device but fails. It goes through first 2 steps, and fails on the last step where the device is trying to connect to the network. I am using a 2.4G network, and the signal strength is excellent. None of the other devices have any problem connecting to the network.
- I tried resetting the wifi on the S5 Max multiple times (by pressing the power and home button at the same time) and repeat the process, same result.
- I have tried uninstalling and installing the roborock app multiple times but no luck.
Please help me out. This is very frustrating, as I was really excited to set it up and use it. I really don't understand how a simple step like connecting to a wifi network can be so painful!
EDIT: After about 10 attempts, I could connect to the device in the app. It seems okay now. I hope the problem doesn't occur in future when connecting to a different network, in case.
Regards,
Swapnil
Thanks for your update.
Glad to hear that you figured it out.
The issue is back and it is incredibly frustrating.
It's not even 2 weeks after I got my S5 Max, and today the Roborock app started showing 'Device Offline'. Now it WILL NOT CONNECT to wifi!. I have tried reseting the wifi 15-20 times now, it gets stuck on device connecting to wifi step for a few minutes and then says failed to connect.
Again, there is absolutely no issue with my wifi connection/router.
This is a very bad experience for me. Please help me out with a workaround, or a replacement if the device is faulty, or I will be forced to return it.
Not sure if it helps but things seemed to be better for me when I turned off 5g wifi so my phone and bot were then on the same network. Also, I assigned a fixed ip for the bot on my router.
Try reboot the robot and router and re-add it.
You can reset the wifi and reconnect it to the home wifi network.
Also, you can try the methods "Mark" mentioned.
Thanks for the response Mark!
