S5 Max side sensor sensitivity’s?
Hi All
This my sharing after 2 days of S5Max usage. Compare to Mi Vacuum, the side sensor Is
not that accurate, S5M use to knock my table leg, and the same small space Mi Vacuum can enter and S5M not entering. As the laser positioning is not same so this might happen. Why this can be happen , it should be a improvement.
  • Hi All
    not that accurate, S5M use to knock my table leg, and the same small space Mi Vacuum can enter and S5M not entering. As the laser positioning is not same so this might happen. Why this can be happen , it should be a improvement. https://shareit.onl/
    issue got solved!!
    I had the same issue a couple of days ago. My collision sensor was clicking all the time too. I cleaned the sensors and it worked astoundingly well. Also, check if you've the most recent updates. I found a discussion where students used tape to make the hole (where the side sensors are) smaller. Though I didn't try this solution.
    Joshua, freelance writer
    https://cheapessaywriter.co.uk
  • Hi folks
    I am sharing this after 2 days of S5Max usage. And compare to Mi Vacuum, the side sensor Is
    not that accurate, S5M uses to knock on my table leg, and the same small space Mi Vacuum can enter and S5M not entering. As the laser bazoocam positioning is not the same so this might happen. Why this can happen, it should be an improvement. https://chatiw.pro/
ReubenBrown
