I love the multiple pass option, but it is not as useful as it could be if the second pass was at a different angle. Perhaps rotate the main passes by 90 degrees with 2 passes and 45 degrees with 3 passes. This may not be the "best" battery performance, but it would clean the floors much better.
Please consider or inform me how to adjust my settings to perform this cleaning pattern.
Thank you for the awesome Robot Vacuum!
I came on here to write the exact same comment, please incorporate!!
Thanks for your suggestions.😘 We would note it down.
Not ideal but I found a work around.
I chose zone cleaning and created two overlapping zones so that the longs sides are rotated 90 degrees to each other. This forced the bot to change direction of the mopping for each of the zones.
I also have a bug in that for some reason I cannot select multi-cycles for zoned cleaning. Is that just me or?
I posted this bug here: https://forum.roborock.com/discussion/2558/s6-maxv-multi-cycles-for-zoned-cleaning-is-not-working/p1
Hello, i'e Just got a new Roborock S50 and I would some info from people who have to since longer time.
I am confused about the mopping mode that can be selected in the settings. I don't have any carpet at home, do i need to select the mopping mode while using the tank with the mop? what's the difference if I don't select it?
I would like also to know how do you guys clean the mopping cloth after usage to extend its life.
Thanks in advance!!!usps tracking
