Error 14
My Roborock S5 started to give error 14 after less than a year use. What should I do? How can I request warranty to fix this?
  • If you have wiped charging contacts, could you send us pictures of charging contacts on dock and underneath of the robot as the attached picture "charging contact"?
    When and where did you purchase this S5?
Nima
