Error 3 suggestions?
I've got a S5 that will no longer start and complains about error 3 instead. I believe that this is meant to mean that the wheel are not down but they definitely are.
I have moved the s5 to a new location, checked the wheels and also done a reset with no luck. Any other suggestions what to look at?
  • I've got a S5 that will no longer start and complains about error 3 instead. I believe that this is meant to mean that the wheel are not down but they definitely are.https://mobdro.onl/
    issue got solved!!
    I have moved the s5 to a new location, checked the wheels and also done a reset with no luck. Any other suggestions what to look at? https://vidmate.onl/
welenbaul93
