A way to run without using a map or any other solutions?
I gifted my parents an s5 max and I'm running into an issue because there doesn't seem to be a clean without map function and there is a limit of 4 floors.
My parents home has 3 floors but has 4 areas that are separated by a small flight of steps. (3 areas on the ground floor and their master bedroom steps down by two steps. I've currently have it set up to clean the main ground area on schedule but it'd be awesome if there could just be a 'clean without map' button since my parents aren't tech savvy enough to fully understand the app.
Right now, my solution is: teach them to delete one of the smallest maps and remap a new room every time they want to clean one of the step down areas. I feel like that'll be a bit too complicated. Does any one have any better suggestions?
  • My parents home has 3 floors but has 4 areas that are separated by a small flight of steps. (3 areas on the ground floor and their master bedroom steps down by two steps. I've currently have it set up to clean the main ground area on schedule but it'd be awesome if there could jshowboxust be a 'clean without map' button since my parents aren't tech savvy enough to fully understand the app.usps tracking
    i agree!
paulasara84
