my roborock s5 has been dropping the WiFi over the last few weeks and every time I tried to reset the WiFi (pressing spot clean and charge button together to reset) it would not connect. I had to do a factory reset of the device and then add the device and then try and reconnect to WiFi I was successful doing that(even though it was frustrating doing this every few weeks)
Today my luck is run out and even after doing a factory reset, I am unable to get the roborock to connect to my WiFi. I am unable to get it on my WiFi even after resetting the WiFi, brining it close to router, etc.
Do you have any suggestions on how I can rectify this issue
Thanks in advance!
Could you use another phone to take a video showing how you connect device to app and send us the video? We believe video could help us figure out a solution.
We suggest you put phone's camera close to phone screen. Besides, also record how wifi indicator(see attached picture) flashes in connection process.
You could upload video to google drive and share us the link if video file is large.
If you understand the router's setting well, change DNS to 8.8.8.8 in the router's settings page.
Reboot your router and try again.
You could connect it to hotspot from a smartphone.
