Roborock S4 firmware update failed
Hi, My current version is 01.03.58, I received the update notification in the app, but every time I click the update, it stucks and tell me try again. Please help!
  • Pls make sure your robot is on dock and the battery is more than 20% when you try to upgrade its firmware version. If upgrading failed, try methods below:
    1. Check if there is new version of Roborock app in google play or app store. You can uninstall and reinstall the APP also.
    2. Move robot close to router and test again.
    3. Move robot away from dock and reboot it by pressing and holding power button.
    4. Switch region of app and add robot to app again to test.
    5. Change the primary/secondary DNS server on the main router to 8.8.8.8/8.8.4.4.
    6. Besides, you can connect the robot to the mobile hotspot to give it a shot.
    fablebobo
    fablebobo01/06/2021      16:02
    It works! Thank you!
    RR_SupportStaff Member01/07/2021      11:05
    @fablebobo:
    Good to know.
fablebobo
