S6 considers the entire floor as one room
    Please send us a picture of the home map interface.
    You can reset the current map and re-map it.
    There are 4 requirements for robot to divide room on map.
    When robot is creating the first map,
    1. Map saved mode is enabled
    2. Robot starts from dock;
Kmrmca
