I recently purchased a roborock s6 MaxV and have two questions:
1) My floor plan currently has one hall and 2 bedrooms. I want the vacuum to sometimes clean behind the bedroom doors (when I'm around to guide it). Any ideas on how to do this in the most efficient manner? I can make the vacuum go to a point inside a room, close the door and spot clean behind the door. But doing this for 2 bedrooms is more cumbersome than manually vacuuming those sections with a handheld dyson. Would appreciate suggestions.
2) On this same floor, I have two more rooms that have 2" thresholds so my roborock hasn't been able to make it to these rooms. I manually lifted it and placed it in one of the rooms and the first time around it thought it was in one of the existing rooms and started changing my original map. I'm not sure how to undo these changes. The second time around it started making a brand new map. Is there a way to get the roborock to the new room but have the room be part of the existing map?
Thanks!
For (2) I was able to build a ramp (with cardboard) for roborock to go over the threshold. My existing map is getting updated, but the new areas are in gray. How do I merge the existing room with these newly found gray areas? Thanks!
There was no way to merge the existing map with newly scanned areas. I had to delete the whole map and start over. Frustrating but hopefully a one-time issue.
For 1 I run a normal clean but close the door after it enters the room When its gone around the room I then open the door again so it can get the next area to be cleaned.
If I don't have the inclination to do this I use low powered electric leaf blower to blow the dust out from behind the door and other inaccessible places.
Thanks for the tip Mark. I did the same and it worked great!
