S6 dustbin sensor
S6 dustbin sensor
Due to a problem with my fish tank, the floor got wet and my S6 got some water in it. This has caused the dustbin sensor to fail. I have one on order but want to know how to bypass it so I can use the vacuum in the meantime. Can I jump a couple wires? Or do have to install a resistor? With how much it takes to get to the sensor I don’t want to do trial and error.
    What do you mean by refer to dust bin sensor? You can send us a picture for reference.
    Also, you can set no go zone around the fish tank, then the robot won't go there anymore.
    Kelly
    Kelly01/10/2021      15:29
    Kelly
    Kelly01/10/2021      15:31
    These are for dustbin and water tank. Both were damaged from water.
    RR_SupportStaff Member01/11/2021      08:49
    @Kelly:
    Did you disassemble the device?
    Could you send us the serial number of the S6?
Kelly
