Hello.
I bought in local market non washable filters for my roborock s5 max. This filters is dedicated for first generation of roborock vacuum cleaner, but is should be compatibile with second generations of roborock.
I wanted to ask if these are the original filters
I will add that the vacuum cleaner recognizes these filters without any problem. I am asking about it because I noticed a slight dust coating around the gasket touching the vacuum cleaner housing, as if the filter was not exactly attached to the vacuum cleaner housing.
Hi, pls check the attached file to see how to distinguish the OEM ones
Thank you for the information. I have a question, has roborock ever produced non-washable hepa filters with mesh on the dust container side?.
As you can see in my photos, the filter has no markings on the side (but these are the markings of the filter that can be washed), there is also no embossed V2.0 mark, only the number 2. Mainly I mean non-washable filters. Does roborock produce such and what markings do they have, what do they look like and whether they have a mesh on one side?
My filters have SDLW01RR product number.
We produce non-washable filters. The pictures you sent us look like authentic non-washable ones.
