Error 13
My roborock s50, something error 13, when i put in docking. Even the i already cleaned the charging contact.
It is become worse lately. How to fix it ? Tq
  • If you have wiped charging contacts, could you send us pictures of charging contacts on dock and underneath of the robot.
    The indicator light on top of the dock should be solid on without the robot and off with the robot placed on it.
    https://youtu.be/LHupFrt14BE
    check Youtube for error 13.
    Often it is a electronic overcurrent fuse to be replaced or if you are not familiar with a soldering iron replace the main board.
    Use RUILON SMD2920P185TF SMD2920 1.85A PTC Resettable Fuse
    as replacement.
    For me that was the fix!
    Kind regards from Germany
Suryadi
