Roborock 5 Max -- unit offline
Initially used the Roborock app and was able to use the unit. However, map edit/saving was not really working very well, so also installed the Mi Home app. Unit worked fine under that app. However, when I then tried to use the Roborock app again, it said the unit was offline. Can you use both apps with the unit or must you only use one of the two apps?
Tosaman
