Rocorock S55 no map ?.
For a long time now, the map cannot load
How can i get it to work? Read somewhere that changing region to china mainland would help. But it says that it won´t let the app operate there and shuts down.
I´ve tried almost anything. Is the RMA or?
alexsunny
    The map used to work well, right? If that's the case, please do not select the region to China.
    3. Take the robot off the charging dock, reboot it by long hold the power button and run the app again to see if it works.
    4. What is the size of your house? not size already cleaned, but your house's whole size.
    5. If you are using Mi Home, tell us which region your Mi Home selects and switch region to the US or Singapore, then re-connect the robot to Mi Home.
    6. Clear cache of app.
    7. Reinstall app to have a try.
    8. Please use your phone data instead of wifi to see whether map will show up.
    9. Do you have any other Xiaomi's device, like camera, lamp?
    RR_SupportStaff Member02/11/2021      02:59
alexsunny123
