Error #8
ROBOROCK S5max had etror#8 trouble. The unit is clean, no obstacle around, but it keep spinning in one spot and stop. It was purchased 2 month ago. Only worked for the first month. What should I do.
  • Hi, sorry for the inconvenience caused.
    If robot says error 8 stuck issue when there is nothing around it, try methods below.
    1. Robot could not be moved by hands, or it will get lost in room and may say error 8.
    2. If error only happens in one place frequently, send us picture to show how the place looks like.
    3. Turn over robot to check if anything stuck in wheel and use hand to roll 2 wheels to feel if they are too loose or too tense.
    4. If water tank is installed, remove it to test if error appears.
    5. Please check if there's anything stuck in the front wheel.
    https://youtu.be/-bcjh4p9U3M
Yatty
