I have both an S5 and S5 Max and noticed that my S5 seems to charge about 30% faster than my S5 Max even though I believe they have the same size battery. Both units are only a few months old. Any thoughts?
The charging speed of S5 is faster than that of S5MAX.
Thank you for confirming that. Any reason why?
Because the rated power of the charging dock of S5 is larger than that of S5MAX.
Is it possible to use the S5 dock to charge the S5 Max? Thank you for your help...
Hi, thanks for your reply.
We don't suggest you do that because their dock are not interchangeable.
There maybe the issue that the robot won't find the dock or fail to charge.
