Can I save a spotclean area?
I have a wooden floor, with a small carpeted area. On this carpet stands a table the children usually eat. The carpet requires regular spot cleaning.
I cannot seem to be able to save that particular area as a location to spot clean. So every time I want the carpet cleaned, I have to draw a box around the carpet on the map. It would be great if I could save that area. The carpet is in the middle of the room, so is cannot make it a separate room with the divide option.
    Sorry to tell you that the feature is not available right now. But maybe you can try this: you can divide the room where there's the carpet in the pattern of a hashtag#, with the carpet staying in the middle square. Then merge the rooms surrounding the square. You can give it a try.
Rbrck
