Roborock S5 MAX releasing too much water
Hi everyone. I´ve had the Roborock S5 MAX for 4 months now and it was working fine until one day it started releasing way too much water when I mop and has been doing so every time I use the mopping mode. I´ve always used it with the water level on HIGH and it was fine, but now, even if I put the water level on LOW it still releases too much water, and the water accumulates on the mopping platform, getting the floor super wet when I remove the mop. Has anyone had this problem or have any suggestions to fix this? Many thanks.
  • If you find puddles left on the mop cloth bracket or on your floor, you can try the following:
    1. Use a piece of dry cloth to clean water-out holes underneath the main unit, and then use a needle to poke the holes to make sure nothing gets stuck inside. See the attached picture for where to find the water-out holes.
    2. Apply some oil into the area surrounding the water-out holes, see attached picture. Please do not add oil directly into the water-out holes. Just a little bit oil is recommended.
    Any kind of oil will do.
  • Any update ? almost half year with this problem
    RR_SupportStaff Member04/10/2021      10:13
    @MonkeyShark:
    Hi, please contact support@roborock.com to get further assistance.
LuigiSC
