S6 Internal Error?
S6 Internal Error?
I have had my S6 for almost two years and never had any issues. Starting this week as soon as it starts a clean it immediately gives me an internal error. I have factory reset it and updated the firmware to 01.27.00. It is still have the same issues. What can I do to fix this??
  • Hi, thanks for reaching out. Could you check the detailed error message? See the picture below:
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
DanielFormoso
