Roborock could not stop finding dock after going back to starting point
”you don't need to move the charging dock together with the vacuum to the other floor. You just need to move the vacuum alone to map that floor. The vacuum will come back to the starting point where you let it start the cleaning” in : https://support.roborock.com/hc/en-us/articles/900002181666-How-to-create-multiple-maps-for-multi-level-house-
I put charging dock at 1st floor, I just moved Roborock S5 max to 2nd floor and let it clean. After it cleaned the 2nd floor, it could not stop finding charging dock after going back to starting point , it just went around to find charging doc. Does my Robot get something wrong? What do I have to do?
    Would you please check if the steps you've taken to create the multiple floor maps are correct? Especially the fifth point:
    First of all, please make sure there's WIFI coverage on the other floor.
    If there is, kindly follow the steps below to create the multi-floor maps:
    1. Tap the "Edit map" button on the bottom right corner of the map, and choose "My Map" from the pop-up banner.
    5. Make sure the robot is now located on the other floor. Then press "Create", and "Clean". The robot will speak "Starting to clean". Please wait until it completed the cleaning, and don't manually move the robot or interrupt the process.
    You can check the attached screenshots for your reference.
Anna
